Trailer wire harness
BazLR3
Noob's second question.
The LR3 which I am buying this week does not have a hitch installed. I need to tow a 6000 trailer and will need the wiring. My trainler has 5 straight pins. Which harness would be most suitable for my needs? Do all LR3s come prewired form the factory (fingers crossed?)
Thanks.
ryan-in-oregon
Thanks.
Only the ones with the tow package come wired. You can buy the harness from your local Land Rover retailer and it is simply plug and play (very easy with the included directions). It will have a 7pole and 4pin plug. You can buy an adapter at many autoparts stores to go from 7 to what ever you need... Of course this is the us harness if you are anywhere else I'm not sure what plug assembly comes on the harness
vladyshka13
hitch and wiring
I bought used hitch on ebay, and wiring from AtlanticBritish.com or BritishAtmantic, don't remember, Cheaper then a dealer and the same outcome.
BazLR3
Hi there, thanks for the tip, is it also plug and play?
roverman
It is. It is the same OEM part, just 1/2 as much.
vladyshka13
In order to connect the wiring you need to disconnect plastic connectors at the end of the wires in your LR3. It was not in instructions, so it took me some time to figure this out.
