transmission acting funny
F
fxinc
02 Disco II, 80,000 miles. Runs and drive fine. Recently, when I come to a stop, the trans will surge forward like it's going into another gear. Then the M and S trans lights start blinking. I checked the trans fluid level, and it was full and clean. Checked the ECU, no pinched wires or moisture. Any ideas on what may be causing this?
F
fxinc
Well, took the truck to the shop before I did any damage to it, and here's what they found:
1. bad MAS (mass air flow sensor)
2. bad neutral safety switch. Failed due to moisture driping from the ac.
F
fxinc
Update: Problem solved.
After having my local shop not be able to solve this problem, I decided to go to the LR dealer. My experience was nothing like the horror stories I've heard about going to the dealer, rather it was pleasant. Anyway, I dropped my disco off the closing of the work day, got a call at 7:30am the next day. They found out the problem, got my ok to do the work and it was done by 1:30pm. Price wise, it was a lot less than I thought. LR of Hanover, MA gets two thumbs up! Oh yea, the problem turned out to be the crank position sensor. When that goes, it cause a world of wierdness.
tragic1
