codemonkey
- Joined
- May 21, 2008
- Posts
- 121
- Reaction score
- 0
I've recently experienced two faults with my '05 SE, one for the first time today and the other for the third time today. They may be unrelated, but I'll put them both here in case they are related.
First up is a transmission fault - this happened for the first time today, and has only happened once. I had been driving all day, including some offroad/low range driving, and was headed back home on I70. Traffic was backed up from the Eisenhower Tunnel going east, so we crept down a long, long grade - maybe ten miles - in about an hour. Because of the steep grade and high altitude (11k to 8k feet) I kept it in 1st and 2nd gear, creeping along, to keep the brakes from overheating (pretty common up here).
After about an hour of this, while stopped (yet again), the warning "transmission fault, come to safe stop" flashed. A few yellow warning lights came on, I can't remember which, and then it said "transmission lowering". We were stopped for a few minutes, so I turned the ignition off, waited a moment, and turned it back on again. Fault gone, mostly normal. The only weird thing is both the offroad and normal height indicators were lit by the switch, and the up arrow was flashing. I hit the down switch, it picked normal height, and seemed happy. I frankly couldn't tell whether it had raised or lowered in any of this.
I continued on home, leaving the shifting to the transmission, and it was all fine. Has anyone experienced this? My guess is that the transmission may have overheated with the slow speeds and lock into 1st and 2nd. At the same time, traffic jams at high altitude are a fact of life in Colorado these days - this won't be the last time I encounter these conditions.
