Vibration
I luvRovers
virginia
hello, I am the original owner of a 2016 LR4. 122,000 miles. I have a what seems like a harmonic vibration in the steering wheel and column. It only happens in park and at stop. It does not go away when I am in neutral. It is not there when I am driving. When in park if I put my foot on the gas it immediately goes away. Does not go away when the heater is on or off. Both spark plugs and wires have been replaced. Recently had the PVC valve replaced due to 2 emission codes. Thank you for your suggestions!!!
Rover Range
Texas
Sound like collapsed front motor mounts.
With the hood open.
Foot on brake. Do not let off brake. Place in drive. Give a little gas and see if the engine jumps up. If it does, mounts are bad.
DylanM
hmm...have the same symptoms and am worried it is the mounts. Assume the job is a pain on the SCV6...
