water problem
E
E110004
I have a discovery II...after a hard rain, water comes in the truck through the seat belt openings and the a/c control openings over the back seat. Someone mentioned it could be that the sunroof drain tubes are blocked. I tried to clear them from the top(opening by the sunroof). Does anyone know where the tubes end up under the truck?
Z
zukiny
I had a lanica that the sun roof use to clog up, i used an air gun to blow all the crap out from the top. after i did this it was easy to see were they came out as there was a pudle of water on the ground.
I would also check to make sure the torques screws that hold the window glass are not loose... this will cause issues as well.
Last time I got wet from mine I found one screw had came out completly... not cheap to replace at the dealer either, but with another rain storm coming you do what you have to.
E
E110004
thanks, i tried to run a wire down the drain tube, but it woudn't go to the end...looks like i'll have to find a sunroof installer to see if they can fix it.
E
E110004
i noticed there was some play on one side of the track...do you know the best place to order replacement parts? I tried to run a wire down the drain tubes and it would only go so far. I can't find where they drain out under the truck or I'd run it up from the bottom. Any ideas on the location?
BCNJ
