went to re align my steering wheel
98GRDisco
Rotated my steering wheel (removed power steering pump)and now the rotary coupler is making a ticking sound how can i fix it?
Okay so we are on the same page... which part are you referring to as the rotary coupler.
If the below part.. then you may need to either replace or attempt to clean and lube...
98GRDisco
It is located behind the steering wheel, like in the second drawing number 6 item
That isn't lubable... if it is making noise, then that may require a replacement or might just be a loose bolt...
98GRDisco
there is a spring and pin that causes it to tick i just taped the pin in and no more sound and everything still work ( haven't tested the cruise yet but i think it will be fine
thanks for your input
Glad to hear it was that simple
SulliMtn
