will not start, lock or anything
gotmullet
Need Help!!!
I was working on my power window to see what was wrong.To see if it's window motor, regulator, or window switch. I found out that motor would turn only one direction, up. It could be the window switch. After i put everything back and finished the job. I inserted my key, the car would not start. I notice not lights, nothing except for my air bag. and now I can't even lock my car.Whats going on????????????:eek:
tlt
Sounds like you dead shorted something maybe. Start be retracing your steps, disconnect the battery, charge, and test it. Could always be one of those coincidences that the battery chose that moment to die. Check for fusable link on main battery cables.. if there is one (did it blow), etc.
gotmullet
do know what happen. but i got it fix. none of the fuse was blown. after i tried to crank it a dozen time the battery die. recharge it over night and for some reason it decide to work.
Sid1577
