ZF4HP22 Clutch Correction Kit?
L
LisaB
I was looking for a rebuild kit for my transmission in anticipation of mine failing when I found this part on www.bulkparts.com under ZF rear wheel drive:
"The ZF4HP22 Clutch correction package is used to reduce cross leaks at the turbine shaft. Cross leaks can partially apply the FWD clutch when the transmission selector is in in Park or REV, causing BURNT FORWARD CLUTCHES & SLIPPING."
Does anyone know about this? What's the diff between a 22 and 24 model?
Thanks,
BCNJ
