Oil filters
CMGRover
Who makes the factory brand oil filters for the 4.4l LR3? Just wondering. Would it be Motorcraft?
schafari
It is not Motorcraft. Few if any Ford parts on the LR. The only Ford part I am aware of is the brake controller socket. I believe the oil filter mfg is Mann.
nwoods
Sorry but that is bad info. Quite a few of the bits actually have the Ford oval stamped right on them...not to be confused with the Land Rover oval :)
I'm not sure about the filter though.
CMGRover
Next time I get it into the dealer I'll ask. It's white, like Motorcraft stuff, which I believe their oil filters are Pureolator's.
bscmich
FYI, the 4.0L V6 OEM filter is absolutely Motorcraft. Same filter used in Mustangs and other Ford models. Comes in a Land Rover box, Motorcraft on the filter.
Disco Mike
If you are looking for a good filter, don't worry about who makes the factory filter just buy a Mobil 1 oil filter and you'll be set.
Royal Purple says they make the best but if you go read some of the oil filter comparison tests, it is hard to beat the Mobil 1.
GMTIIFAN
Wix makes an oil filter for land rover and jaguar. WIX - Oil Filter
Part Number: 57302 (from O'Reilly auto parts) It's a possible option. There is plenty of info on the web about oil filters and which ones are better.
Disco Mike
Every body makes a filter although only a few are really worth buying.
Disco2TrailEdit4
