Rear tire carrier LR4
danrhiggins
I'm going to be putting a Baja rack up there. I might switch to a smaller jack if it becomes an issue
You can probably just pull it off if you get into a narrow section. I keep trying to follow my friends in Wranglers onto trails that are probably better suited for ATVs. :argh:
ivan gonzalez
I still can't believe nobody is fabricating these and selling them.
The main problem on fabricating these as my friend from the shop will say "not every bumper/car sits the same" if your bumpers a bit off you could have the arm a bit tilted to the side. I ask him if he would fabricate these and he said in order to get a job he's comfortable with he needs the car unless you have a shop that will weld this for you for the install. They did have a hard time getting some things right like how to hold the tire in a fix position once its unlatch and even the latch itself was a problem. I can have all the parts made and ship them but you will need someone the can weld to finish the job.
ivan gonzalez
He made it out of the cylinder from a caterpillar shock absorbers cylinder. Kinda weird but it won't rust, needs no grease and yeah it won't rust.
Surfrider77
Wish someone would mass produce these too!! Kills me that Kaymar is the only player on the market and it is not at all optimal, as it completely blocks one of the tail lights.
Looks great Ivan. I am quite jealous! =)
ivan gonzalez
I can get him to build and send you everything you will need to finish it on your truck but you will need a shop to weld and if need be adjust it so the arm is straight. Not sure on how much $$$ since he only charge me for parts and not labor.
Ryby
What about the carrier Voyager makes? Any thoughts/feedback from anyone on those? Doesn't cover up the taillights. I was considering the half length arm version.
Looks great! My buddy is working on my swing away that we will weld and fabricate to my Kaymar bumper. I hate the swing-aways that Kaymar provides, so I am doing my own.
I did get the Baja installed - looks awesome and so much more useful space.
Vintage99
