Showoff Your LR4
Are you using spacers with those wheels, or did you grind the calipers. If spacers, what size?
What size are your tires?
Sweet LR4.
Jazzy
Monterey, CA
Thanks. Yes I’m using spacers. Tires are 275/65r18. Wheels and spacers are from lucky8. I also installed proud rhino off road extension kit which I put spacers on top of air struts and used lift rods to fit tires...once again from lucky8. The rear tires don’t rub at all, but the front rubbed only when fully locked/turned. I had to cut some of the frame horn with 4 1/2 grinder...actually pretty easy. Off road with new tires vs 255/55r19 is like night and day...so much more sidewall when airing down.
iconoclast
In, Out & Around...
Jazzy
Monterey, CA
Getting a uniform spool is fine, actually have decent amount of space around drum... issue is I can’t engage the free spool lever, so takes a bit more time, but hasn’t been an issue.
I have a superwinch tiger shark 9500, so had to remove solenoid cuz no room for solenoid on top of winch...bought 2 gauge wire and made an extension kit to run solenoid inside of engine bay. Bolted on passenger wheel well
Also, I initially installed a hawse fairlead, but didn’t have the right spacers b/w discrete winch mount and my bumper, so when winching a gmc truck out of mud from an angle few months back, bumper started bending bad. So, cut more of bumper and installed rollers...
iSurfvilano
North Beach, FL
View attachment 8266 View attachment 8267 View attachment 8268
Solid setup, I can appreciate how clean it looks. Great job!
DugLR4
NJ
sweet LR what type of wheels are those? and what size tires do you have on?
