Are LR4's actually bi-xenon?
mklinker
boston, ma
I just got done upgrading my 2012 LR4 to xenon headlights. I was reading the workshop manual, and it talked about how the xenon headlights were bi-xenon headlights. That implies that the xenon bulbs put out more light (some solenoid inside the bulb) when you switch to high beams.
From the manual:
NOTE: If the lighting control switch is in the OFF position, the xenon lamps do not operate when the high beam 'flash' function is operated. If the lighting switch is in the headlamps position or AUTO position with the low beam lamps active, the xenon low beam will remain on when the high beam 'flash' function is operated.
Are the xenon headlights on an LR4 actually bi-xenon, or will the halogen high beams always come on when you turn on high beams?
The halogens provide a far reaching spot further out while the reflector in the xenons moves to focus the light further out than they do on low beam. I had a Volvo V70R with the same system except that in high beam there were no halogens (Volvo used them as DRLs in North America). The high beams were very weak with just the xenon operating.
Quijote
Metro Boston
I also had a V70R and can confirm that the Xenon high beams were super weak.
Nechaken
In the 2014+, there is only a bi-Xenon lamp where the reflector moves (no halogen high-beam).
I think I've seen several comment that the 2010-2013 lights are much better with both the Xenon and the halogen high beams operating at the same time.
I have actually always loved the lights in my 2012. It is probably the best of any vehicle I have had.
Even better since I replaced the halogen high beam bulbs with LEDS.
It's one area where I have no complaints with the Rover.
Lgibson
As a side note, xenon bulbs do not respond well to continual on/off cycling as in European style “flash to pass” use, hence the bi-xenon approach where the bulb is always on. Halogens, on the other hand, have no problem being “dipped” so are better suited to high beam use.
  • joey
