LR4 electricity power cut off issue
jackkyxu
recently I noticed such issue from my LR4:
occasionally, when I start the engine (no matter cold or warm), I could see the time/date in the instrumental panel was reset, and I realized there must be some electricity power cut off, but I can still start the engine.
The car is used right now about once a week and parked in garage, I can say there should not be any battery drain problem, even car parked for more than two weeks.
any idea? corrosion on the battery terminal ?
Thanks
gabriellarson
US
I have a friend that wanna sell this battery if you are interested I'm gonna send you his email address
Sent from my TECNO F2LTE using Tapatalk
I’d ignore this guy. Looks like a scam.
Anyways, I would check out the terminals like you were mentioning. There’s just a plastic cover covering the battery on the passenger side of the car.
Maybe have an auto parts store load test it as well.
jackkyxu
thanks for your advice, I would do it over this weekend, and my battery is covered with warranty
jackkyxu
report back here
found out the battery terminal clamps were a little loose but shiny (I wiggled it and electricity cuts off), I think from a repair job last Oct,
tightened both and applied the battery terminal protection fluid
lets wait and see
tango90
