1791 Navigation Hack and NEW 2008 Map Disc
toddjb122
I'm looking for a 1791 enabled disc ...can anyone help me with this?
If 1791 doesn't work on your truck now, it never will.
If it works now, than you want to copy a disc in the manner specified in this thread. That will allow you to remove the software update that blocks the 1791 access.
kneedeep
I currently have a 2006 disc and it works fine but I'm looking for a 2008 one.
angasreid
So I was recently messing around with a 2005 Lexus GX470 with Nav also made by Navteq.
On the Lexus, one can do a procedure to enable changing destination while driving; much like the Land Rover. However, after doing some research they also have the same issues with the "loading.kwi" file. The latest version of the Nav DVD cannot be hacked to enable destination on the go. When the lastest DVD is installed,"loading.kwi" installs a file that blocks the destination on the go. Some claim to have made "hybrid" discs, but I've tried many many times and didn't get it to work.
Here's the interesting part, if one updates their Nav system to a newer version of the software and accidentally blocks the ability to change the destination on the go, they can fix it. All you have to do on the Lexus is, put the old DVD in the player, and unplug the battery terminal for about 10 min. Once the memory seems to be erased and the terminals are hooked back up, it then installs the software again. Based upon whatever disc is in there, you can once again use the destination on the go feature, but with old maps of course.
My question is, who here has a 2005 or early 2006 that originally had the 2004/2005 DVD. Then, if you updated the Nav system to a official LR DVD and blocked 1791, try the procedure above. I think I remember someone saying something about this perhaps, but it's worth a try. If it works, it may work on newer LR models too.
Here's the Procedure if you don't have 1791:
Eject the more recent DVD you have. Put the 04/05 DVD back in. Unplug the battery terminals for 20 min maybe 30. Hook the terminals back up, see what happens. I myself would try it, but I am still running the 2008 DVD. I like my 1791 ability too much.
If it works, this could be interesting...
Augen1025
I couldn't find loading.kwi
Angas, thank you very much for the info posted. I tried to follow the procedure to get rid of the blocking but I can not find the file " loading.kwi " and it is because I have the 2005 464210-5420 version....SOL .... now I need to get the updated Map and live with the Nav the way it is set .... :mad: :frown:
Augen1025
It works indeed
Thank you Angas. Just Did it and it works flawless in my 2005 Nav.
Cheers,
Roland
dochummer
So, in summary, what's the latest disc that can be hacked? Part number? From reading through the thread it looks like the 2006/2007 disc is the last one to work properly. the 2008/2009 disc does not work. Is there a 2008.1 disc? Would the appropriate part number for the latest disc be YIW500210? I have a 2005 LR3 with the 2004/2005 disc... Thanks.
Last North America disc that can be successfully hacked to preserve the 1791 bypass is the 2007/2008 update, Land Rover Part # 6H42-10E898-BB. On 2008/9 and later the hack doesn't "take".
dochummer
Thanks umbertob. Searching for info on that part number it looks as if it may have some bugs/glitches? Is that the case? Would it be better to go for the 2006/2007 version?
