2007 RR-SC Suspension Fault
B Malloy
Texas, USA
Recently a "Suspension Fault" message appears at startup for about 15 seconds. No indication of an issue and screen shows all 4 wheels at the same level. Any thoughts?
Air pump may be about the go to the afterlife or you have a controller issue, or if you are real lucky just a leak.
REGAN_LR
In addition to Joey, an issue that I have faced when getting these warnings is failing wheel position sensors. Too expensive to replace them all, but will fail at some time.
B Malloy
Texas, USA
Update:. Used RSWSolution device and it showed this issue - "Air pressure too rapid a rise to reservoir". I cleared the fault but it immediately returns. What could cause this, so it can be repaired. The fault message only appears for a few seconds at every startup. Suspension appears to work correctly otherwise.
Too rapid a rise, almost sounds like a pressure regulator, but not sure it has one inline. I don't have a manual for the newer rovers.
