On my 2016, after I had allowed the old S/S battery to go dead for probably 6 months or so:
For the physical bit, it's a simple swap.
Just watch the connections/terminals on the new battery as not all batteries have the correct terminals.
There is a "heat shield" that is attached to the factory original battery that is glued on, but it's easy enough to carefully take it off with a putty knife or similar (2 minute job).
For the software bit:
I replaced both the S/S and the main battery at the same time, and I did do reset for the main battery as part of that process.
So I cannot state with certainty re: resets for only the S/S battery.
But I can tell you that after I completed both batteries and the reset, the S/S (unfortunately) works again..., but at least that idiot light is off !
I did mine about a year ago and it was stupid expensive at Rover, so I found a battery in the UK.
Even with the expensive shipping it was $100 less that getting it locally.
The battery is an Exide EK151
I recommend:
Groves Batteries
Cheltenham, UK
I see they have them in stock (as I write this) for 56GBP, plus shipping.
My shipping was about $100
They were super easy to work with and (at least at that time) shipping was fast.
