My 2007 LR3 A/C compressor is making noise from under the hood and can be heard from inside the vehicle. Drive way test confirmed that the actual noise is coming from within the engine compartment and not the blower/ductwork inside. When switched on it sounds like a bearing slightly whining and changes pitch with the engine RPM. Switch the A/C off the the noise stops.
Anyone experienced this? Or found a fix? Wonder if it could be low Freon or the compressor beginning to near the end of it's life?
