Brake replacement
zgrmns
Thanks. No leak. Master cylinder fluid is full. When I was compressing the one cylinder on the caliper, the other one pushed out really far and a little fluid came out. I was able to push it back in but I'm wondering if that's when some air got in or something???
uptick1028
Most likely got some air in there then...I would try bleeding the brake lines. I am surprised the caliper piston popped out when compressing the other. I usually do one at a time so impossible for the oher caliper piston (cylinder) to come out. Still if you had the lid off of the master cyclinder I am surprised it pushed out the oher caliper piston.
uptick1028
When I stated "I do one at time", I meant that I only remove one caliper at a time.
zgrmns
Yeah. The front calipers each have two cylinders. So when I pressed the one in, the other one right next to it popped out.
Vintage99
