M
M3orLR3
i understand that the LR3 has a dial to indicate off road conditions.
my question is how fast can you go in each position. for example, if i am in packed sand, like a dried river bed, with the occasional rock that needs straddling, what setting would i use? and how high will the LR3 ride? can i be doing 30 or 40 miles an hour and still have maximum ground clearance?
another quesiton is about changing settings. if you are on a trail and come up to a section that requires a little rock crawling, do you turn the dial and then turn it back 15 seconds later, or is it not really made for that...?
maybe my questions can be summed up better this way: how much ground clerance, and what is the maximum speed, for each suspension setting?
