Robairx, did you reuse your old oil pump ass'y on the new motor? (I had to ask)
The only instances I'm aware of oil pressure loss @ higher rpm are foaming (not likely with such a deep pan) or pickup tube sucking air (sealed @ connection?)
Do you have the RAVE cd? - I think it has oil pump specs (clearances, pressure relief valve spring length)
luck,greg
luck,greg
