Just thought I would post an update. I finally was able to crawl under the truck and drop the oil pan. Its raining, and I live in an apartment complex, so no cover from the elements. Talk about a PITA. I sure miss my garage. At least its not snowing yet. Anyway, I got the pan down and immediately saw the problem. The oil pick up was very loose. I was able to remove the two bolts that held the pickup by hand. The pickup screen is 90% clogged up with coagulated oil. I am fairly certain that this is the culprit and plan on cleaning the pan and ordering a new pickup. I cant find the o-ring that seals the pickup to the block and the pickup is so filthy, I think I may be ahead in the long run just ordering a new assembly. Although I cant drive Molly until I get a new pickup in, I feel quite relieved that I found the problem and can fix it. If this had failed the next step wouldve been a new timing chain cover, which contains the oil pump. $700 for these would definitely hurt. Well, Dave Lucas, you nailed it dead on. Once I get everything buttoned back up and tested, I will post my, hopefully, final results. Everyone has been very helpful! Thanks again to everyone. Its help like this that keeps me from getting buying a Jeep.
