Showoff Your LR4
Bama4door
Great looking rack. I say this in the true spirit of fellow Landy owner camaraderie: War Eagle to that! :biggrin:
Haha! Good to see some fellow AL members on here. Both of my sisters go to Auburn...looking forward to football kicking off next weekend.
DonMitsu
Testing the BFG tires :)
Surfrider77
They sure do look good!
285/60/18 size is releasing tomorrow. (Sept 1) according to the BFG website.
Well, it's been a while since I posted anything, but I finally had my LR4 thoroughly washed and for the first time in 2 years, clay barred, properly waxed, and sealed. I have never seen it so shiny and I am almost embarrassed to drive it! :)
danrhiggins
Ha! It does look it bit odd to see it so well kitted out - and at the same time so very clean!
danrhiggins
And how do we think the 285/60/18 will fit? I will be needing to buy a new set of 18" tires in the Spring. (Its been a bad couple of days for me and tires.) I thought I would move to BFG as a number of those on the forum seem to like them.
Surfrider77
I currently run 285/60/18.
It just gives you a slightly wider footprint. Sidewall height (overall diameter) is negligibly lower.
Fitment issues with our trucks come down to the diameter. Ie: The wheel hitting the frame horn on full lock. Wider width doesn't hurt a thing.
jwest
Seattle WA
Dude, that info is not really true.
285/60 is about 1" wider than 265/65 and 285/60 is really not a good choice for the stock 8" wide wheels. You can "prefer" whatever you like, but it's not the best choice.
Width is absolutely an issue on the lr3 [and LR4]. It's ridiculous to say otherwise. Too wide WILL rub on everything unless the diameter is lower. On the other end, a 33" tire will fit fine up front if it isn't too WIDE.
A wider tire will also rub all into the fenders and fender liners if sitting on the bump stops. A narrower tire, even taller, will not due to it's ability to tuck into the fender liner space.
Lastly, the BFG 285/60 is a D load range which is unacceptable for the heavier LR3/4 builds.
