Fuji4
- Joined
- Jul 26, 2014
- Posts
- 506
- Reaction score
- 236
https://www.sonnax.com/zip_kitsSadly no. I’m in Southern California. And explain this zip kit you mentioned.
I did one on my 8 speed. Shifts like a dream now.
A long long shot but three years ago my LR4 went into reduced performance mode on the highway and the accelerator went unresponsive. Pressing it down would do nothing. I shut down and restarted and it was ok for awhile and then repeated. It was traced down to broken fan wiring. A simple fix of the wiring and all was ok. There was mention of a TSB but I do not have the number.
New here. I’m having a very similar situation. 2011 RR HSE, 77k.
4 occurrences, all after driving for approximately 45 minutes. Each time the car will shift, into neutral instead of 4 and maybe 5th. Get a “Gearbox Fault” on the dash but nothing else, except on the 3rd occurrence, a check engine light which resulted in an OBDII code of P2407. Forced the symptom yesterday (br driving harder than usual) and codes reading are P0850-8f (Park-Neutral Switch) and P0729-07 Gear 6 incorrect. (Symptom has not occurred while In sport mode, yet)
Also getting a P0128 and P0126 (both engine thermostat Related, which has been a recurring issue for about a year and has resulted in 3 thermostat replacements by the dealer...) going to clear the codes and see what happens next. Btw, fluid was changed approx 1000 miles ago by me. Level checked. Used ZF fluid.
Going to check the park/neutral switch, Clean it and look for loose wires. It has been my experience that wiring is the cause of many gremlins. I also have a 2005 LR3.
