ryan-in-oregon
- Joined
- Jul 7, 2009
- Posts
- 538
- Reaction score
- 3
Update
Ok. The shock mount is solid Rather the spring mount as the shock mounts to the air spring. After much further inspection the whole assembly is dropping too low. There is evidence of the cv boot rubbing on the lower a-arm as well The problem appears to be in the strut itself however I can't inflate it anymore to find out how low it will go. I might try a patch on the bladder just for the purposes of testing the strut assembly. I also inspected the driver side and it is doing the same thing however it has only just kissed the spring housing. Here are some new pictures I took as of this morning.
This is just an overall pic, you can also see where the spring has rubbed against the frame at full droop. (It gets closer to the fram the closer to full extension you get)
This shows that the a-arm is rubbing on the housing of the spring
This shows that the lower a-arm does indeed rub against the cv boot
Just another shot of the hole in the spring itself due to the a-arm rubbing
