Nope, the TPS (Throttle Position Switch or Stepper) when it goes bad or gets dirty, you just have issues with idle (normally)
If you need the below Word Doc with pics, please send me an email at
[email protected] (yes this is the one off of Discoweb) I download a copy of all tech docs I can get my hands on.
Replacing Vehicle Speed Sensor
byThom Mathie
Low and behold yesterday I went to get on the road for a short trip and only about a mile down the road my truck starts to act up. Under partial load and deceleration the truck would act as if the torque converter would lock and unlock or that the key was getting turned on and off very quickly. I tried the cruise control and it would kick out right as this "miss" would happen. Well it acted very much like it did last winter when my VSS or Vehicle speed sensor went bad.
So today I changed mine. I have heard many questions regarding this so I thought I would illustrate it for everybody.
This is the little bugger. The first one I purchased was $49.75 at the Dealer a year ago I got mine for I believe about $38. Today I called Nathan and they have them for $60 but I decided for speed of getting it back running I would bite the bullet and run to the Dealer. There price $112! the nice man behind the counter gave me the preferred customer discount and it was still $93.
Take note there has been a part change on this item just recently by LRNA as they said that's why the price change?
this job is very easy if you have the correct combination of tools. What I found to be perfect was a 3/16 allen driver on 2 6" extensions with a ratchet.
The VSS is located sandwiched between the transfercase and the parking brake drum assemble. It is held in place with a 3/16 drive allen cap screw.
The first step is to remove the plug in connector. a standard straight blade screwdriver is perfect. Lightly push where I have circled while gently pulling the leads it will pop right off
then with the allen driver/extension combination coming in from the drivers side parallel with the ground you can reach the cap screw and remove it
once the allen is free and removed the part will pull right out. Mine was pretty rough spinning compared to the new one. The part has a small square drive shaft coming out of it. This is what spins the sensor.
Now place the new sensor in place making sure to get the little drive into its square drive. Then replace the allen cap screw and tighten
replace the plug connector and your done.
This whole job took under 15 min including backing it onto ramps. and clean up. I think anybody could do this as a first project it is very simple. The tools needed make the job very easy. If you don't own allen drivers go get some. It is a tool you will use over and over.
The best part is the disco now runs smooth again and the bucking it was doing has disappeared.
