Do Your LR3 Crossbars Whistle???
A
AZSTALZ
After many attempts, I have finally figured out how to eliminate the "whistle while you work" syndrome of the stock LR3 Crossbars. Go to your local hardware store and purchase a 1.5m length x 19 mm (5 ft x 0.75 inch) roll of "Sticky Back" Black Velcro. Cut a piece of the "Loop" side (soft side) of the Velcro so that it fits lengthwise across the bar from the inside of one mount to the other. Pull the backing off and apply it to the TOP of the crossbar, directly behind the rubber strip that resides in the middle of the bar. Make sure the crossbar is not freezing cold or has any moisture on it. Firmly press it into place, running your hand across it several times to ensure good contact. Enjoy the "whistle-free" ride. --AZSTALZ
R
roverdawg
Sounds interesting. I'd kinda gotten used to the whistling. Can you post a pic so that I know I've got your instructions down pat before I stick it in place? I'm more of a visual kind of guy....a bit slow on the uptake. Thanks!
A
AZSTALZ
I get my truck back from the dealer tomorrow (bad fiber optic between main amp and the nav screen/stereo) and will post pix of the "jerry-rig" velcro job.... --AZSTALZ
A
AZSTALZ
MArsel
