Akebono Ceramics
....so, anyone have significant experience with these that they can address whether or not they last longer than standard pads?
I know I know, just about anything lasts longer than the OE pads, but humor me here, please.
What is the cost vs. the stock pads?
Mr.BigsLR3
Curious about the dust too.
Geotrash
Much longer lasting and virtually dust free. Have owned 3 sets on 3 different cars and have been 100% satisfied with them. 60K on one set now on the wife's Rodeo and have better than 70% thickness left. Very kind to the rotors (original rotors with 185K on them, on the second set of pads since new. Originals were ceramics similar to the Akebonos).
Dave
cbboard
i got 'em all around about 10k miles ago. brake dust is a minimum. noise/squeal is pretty minimal as well, mainly when wet/off roading. i don't remember the price, but they weren't any more than OEM.
Disco Mike
I have only had mine a few months but thing I noticed are, no break in as such, no dust to speak of, no squeaking or 3 Amigos and they out stop the Kevlar pads I replaced and still running them on a old set of DBA rotors.
Where are you buying them from and for how much?
I've heard that ceramics may not be able to handle heavier vehicles....no concerns on that? Is the stopping power as good as original?
I've also read that ceramic pads may need time to heat up before their stopping power is comparable to their semi-metallic counterparts; have you experienced this?
I very much appreciate this information! Thanks...
JackMac
Some intraweb info. Note the warning regarding large/heavy SUV's.
Benefits
•The surfaces of ceramic brake pads are made from ceramic materials and copper fibers. This is in stark contrast to semi-metallic pads which use steel wool and fibers. While steel is strong and conducts heat away from the rotors, it's noisy and actually acts as an abrasive, contributing to rotor wear and tear.
In comparison, ceramic brake pads are much quieter. They handle extremely high temperatures with little fade, allowing them to recover quickly and cause less damage to rotors. The ceramic compounds dampen noise and shift vibrations to frequencies higher than the human ear can detect, rendering annoying squeals a thing of the past.
When ceramic brake pads wear down, they produce finer, lighter dust than their semi-metallic counterparts. The dust doesn't stick to wheels, keeping them cleaner.
Studies have also indicated ceramic brake pads have longer life spans without ever sacrificing of noise control, rotor life or braking performance.
Features
•Ceramic brake pads have three features not found on other pads: chamfers, slots and insulator shims.
The specially angled or beveled edges of a ceramic brake pad are called chamfers. They reduce the pad's surface area, creating more gripping pressure and reducing noise when brakes are first applied.
Ceramic brake pads also feature slots or grooves cut into the pad to change vibration frequency and to permit gas and dust to escape under high temperatures.
Insulator shims are yet another measure taken to reduce noise. They provide an additional layer to absorb sound and dampen vibrations.
Considerations
•Not all ceramic brake pads are the same. The exact composition of the ceramic-based friction material varies among manufacturers. It's important to know the exact ceramic materials used, their particle sizes, distribution and hardness, because all these factors can affect performance.
Warnings
•Ceramic brake pads tend to be more expensive than semi-metallic pads. Ceramic pads aren't suitable for all applications. Never use ceramic pads to replace the semi-metallic pads on larger, heavier trucks and SUVs, since the metal linings may be required to manage the hefty weights and increased temperatures.
I read the same webpage. The warning sounds kind of generic to me. If manufacturers are making them specifically for the LR3, can we assume that they are produced to handle the weight of the vehicle?
I'm glad we have some beta-testers!
Sully
I found the best deal to be on www.Amazon.com last week and installed them last weekend. So far the stopping power is great. I obviously cannot yet comment on the longevity or bake dust.
