My Java LR
Voodor35
Picked up an 08 LR a few months ago and decided to do a few things to it.
Current mods:
LR4 Led Tails/ Smoke Film
Full Led interior light conversion
Magellan 7" gps w/ LR4 surround trim
Land Rover Coat hanger
Privacy Tint on front doors + front windshield
Smoke Reflectors
Every exterior bulb in LED
Orange reflector from headlights removed + LED strips installed
8000K High and Low beam HID kit
8000K fog light hid kit
Tow Hitch
Shaved Emblems
K&N air filter
Sport Grille with Overfinch emblem
Black Land Rover oval emblem in tailgate
Black painted vent cover
Cross Drilled and Slotted Rotors with Ceramic pads
Anyways here are some pics. First night at home from the dealership.
After some mods
Team Jeff
Very nice! I'm interested in how the GPS is set up, any photos?
Voodor35
You can pick one up at best buy for around $200. I got the lr4 surround trim to make it look nice and flush. Do a little bit of trimming to get it to fit and wire it to the power outlet hiding the cables behind the dash surround. Simple and works great.
crtfour
Looks sharp. Are those factory tails or do any aftermarket companies produce them?
Voodor35
They are factory lr4. I simply replaced the reverse fog and park bulbs inside them to LEDs and tinted the lower portion of the lights. If you do get them just make sure you solder in resistors so your blinkers inside the car can blink at a stock slow interval since without them they will tick tick really fast when you put your blinkers on. Thanks
PE_in_UAE
