Range Rover 2002 model
tukaz05
Hello guys,I have a range rover 2002 model petrol engine. It produces a white smoke while its on silence and its losing power when its on move/running.pls I need an assistant or any technical advice.
Sent from my HUAWEI ***-U02 using Tapatalk
joey
White smoke is water, so I would bet blown head gasket.
tukaz05
I have changed the head gasket and new piston rings but still the problem persisted
joey
White smoke is normally water, black is oil... When you changed the head gasket was the old one bad? Did it show issues? If not you may have a crack in the head.
tukaz05
What do u mean a crack on the head do u mean on engine
joey
Yes sorry, the aluminum head do not normally crack. So sadly could be a block issue. I would suggest finding a good mechanic and spend a couple dollars and have them look at it.
tukaz05
OK thank u for the advice i really appreciate
