Swing away tire carrier
Michael Gain
Clarksville, TN
And how is Rasta working for you, @ishapiro?
Have you looked at the rijidij off-road carrier? It was solid with no rattles and had a great locking mechanism
AdventureTim
Seattle, WA
Hi @AdventureTim , and so how is the Voyager doing in the meantime?
I posted this in another thread, but it has not gone well. Some examples of issues I've had:
  • The instructions include JPG files for the mounting templates, with no indication of scale which make them largely useless.
  • The swing arm is powder coated with no anti corrosion treatment on the underlying metal. Any chip in the powder coat will cause the arm to very easily rust (and continue rusting under the powder coat). See the other thread about Voyager for other examples of people having major problems with this.
  • The gas strut is underpowered to hold the weight of a 31"+ tyre. The strut also has no bearings or swivels for attaching to the arm. Instead, they just have it rotate on a bolt thread - very rough.
  • On mine, the three major studs used to mount the wheel weren't even welded perpendicular to the mounting face. This caused damage to my Compomotive wheels when I bolted them up. Voyager's response was to "hit the studs with a large hammer or block of wood".
  • Due to the way the wheel mounting face is welded to the main arm, you cannot make use of a bunch of standard spare wheel accessories available to the Jeep market, such as Rotopax mounts or bike carriers.
If I had my time over again, there's no way I'd buy the swing arm. It's backyard engineering at best.
  • joey
Land life
