Main Battery Upgrade to Lithium
Anyone upgrade Lead Acid main Battery with a Lithium (LiFePO4) on an LR4 (I have 2012)?
  • Yes
    Votes: 0 0.0%
  • Check this out ..
    Votes: 0 0.0%
  • Total voters
  • Poll closed .
Morro Bay CA
I got a different form factor to work in my 2012 LR4.
But charging profiles with OEM alternator is problematic.
Need technical advice, please.
Local mechanics not helpful. ChatGPT offers a 250A high-output Alternator from Nations - but waiting on feedback from bolting and fitting. Wakespeed WS500 Pro Alternator Regulator?
Went from a 94R/H7 to GRP 24 DL+12V-135Ah DP.
The charging profiles are completely different. Long story short, you can't do that.
However, you can add a lithium battery as a secondary battery with a dc-dc charger. Lithium batteries are sensitive to temperature as well, so be aware. Heat and freezing temps **** lithiums. Most people have their lithium batteries somewhere in the cab, doesn't matter what kind of car, truck, suv, etc.
CRYA
Napa Valley
Agreed. There's a reason pretty much nobody use Lifepo4 as a starter. Just get an H8 AGM from Costco and move on to better stuff! and yeah, add a dc/dc and put a 100ah lithium in the truck.
Morro Bay CA
Thanks for the inputs. I re-evaluated the options and went with everyone's suggestions about dual battery set-up, realizing the 2012 is too early a model to support Lithium directly.
Ideas about best path for inside cab wiring? This would be 4 gauge power wires. I don't think I have enough space inside the engine bay for a 2nd battery. The accessory tray is filled with my lights control module. I'm thinking mounting the battery under sleeping platform ramp I built in the mid-row seating area, but where to go through the firewall?
The driver's side wiring hole used for the light control module was a challenge and there isn't any more space left.
I noticed a similar junction on the passengers side behind the battery well and ECM - so maybe?
Then thinking going under the center console.
Here's a pretty good post to look into. There's links on it that has a TON of details.
CRYA
Napa Valley
But is Traxide still the most elegant, modern solution? I'd think going with a Victron dc/dc for an onboard lithium battery would be great, but haven't actually done this myself, that Traxide kit just looks messy.
People still swear by Traxide and they do a great job. My issue is the "Smart Alternator" doesn't provide constant +13V to sense charging to both batteries, for Traxide or any cheap dual battery modules.
I've been running a RedArc dc-dc with solar and haven't looked back since. If I were to to it again, I'd get the 40A or 50A over my 25A because I upgraded to a H.O. alternator.
Morro Bay CA
Thank you CRYA and djkaosone. The additional posts and your considerations are just what I needed to break through my stubborn persistence that was going to get me nowhere in this case. Now I have a new plan to go after and am recharged in my motivation. Originally my 5-day weekend was going to go South to some trails in San Bernadino as a first run .. now I need to work these tasks - but maybe I'll still get a 2-day trip at the tail end of this long weekend!
I'm thinking about rerouting ALL my wires too and upgrading from AGM (aux) to 2x 100Ah mini lifepo4 batteries with a 3rd 100Ah mini in a pelican case (for portability) that'll simply plugin to create a 300Ah system. Also thinking about chopping up the rear end to accommodate all this.
powershift
Nevada
For the rearmost seats, I want to remove the seat cushion from the seat backs and then mount individual battery cells for a Lifepo4 DIY 12V 304 AH pack with Bluetooth. Right now I have the 4 cells compressed together and set the pack on the seat and the inverter sits on top and a charger (not shown) sits on top of that for a stack. None of it is mounted so I can only drive with just the battery pack by itself.
With the Lithium pack mounted in the sub floor, there would be more space in the cargo area while still having battery power when the rig is off. Also having the battery secured while off-roading would mitigate risk in a roll over. But that opens up possibilities to run a computer, playback music, power a PartyBox, record from video cameras, plug in a laptop and refrigerator. Another bonus is if the starter battery goes down and the engine doesn't start, then you could re-charge it back up from the Lithium battery pack.
