BFG AT-KO's 265/65-18
JThiessen
I'm having these installed this afternoon. Anyone else run them? Will the LR dealer recalibrate the speedo for me (for free?)?
Thanks
zdas04
When I put the wrong size Nitto's on, the LR dealer said that there was no way to calibrate the speedometer.
David
franklin
I was told that there is no need to recalibrate. I also run the BF AT's-have had them for a few weeks now-so far no problems.
davez26
The speedometer/odometer does not have tha ability to be recalibrated. You will have an error in mph, and mileage, but not by much. @ 65 mph by speedo, my GPS reads 67. For me, that is a trade-off I'm willing to live w/. Enjoy the tires.
JThiessen
By whom? With the size difference I'm looking at, its a 5% slower reading. Speedo will read 60 when going 63, 76 when going 80.....
I find it hard to believe that the ECM cant be modified for tire size, especially since they sell them with two different size tires.
davez26
The software has no ability to be modified for different tire sizing.
Two tire sizes, yes, but two nearly identical diameters, thus no need to recalibrate beween the two.
255/6018 = 763.0 MM = 30.03 INCHES
255/5519 = 762.5 MM = 30.01 INCHES
JThiessen
Just an update on this.
First, I called the service advisor about getting the recalibration done, and he stated that I needed to make an appointment to have it done. So unitl, I make an appointment, take it for what its worth. Wether he really heard what I asked, and it can be done, only time will tell.
Second, we just got back from our 2500 mile trip from Seattle to eastern Montana and back. Coming back we ran into LOTS of snow and ice, and am I ever glad I decided to pull those street sweepers off and put on some real A/T's. They handled wonderful in the snow.
On the bad side, they made the LR a little tough to keep pointed in a straight line while running 80 down the freeway. It defintiley made it an "active driving experience". It wasnt a pull to any one side, it was a constant left-right tendancy to wander.
They do look good also. I'll try to post some pics when I get a chance.
franklin
Ditto-my experience is that they are great in the snow. I have no problem with them at highway speeds. Maybe re-check alignment?
nwoods
Realignment for sure, but could also be a factor of tire pressures. No matter what, get your truck realigned. LR3's need to be realigned frequently in my experience (by that, I mean Quarterly).
Then fiddle with your air pressures. Should probably be about 40 in the front, 42 in the rear, or thereabouts (for street use).
davez26
10-4 on those pressures. 40 seems to be the sweet spot.
