wet front floorwells on 95 disco
steveflet
Hi, new to this and discoverys so please bear with me. After rain i get a trickle of water coming down the side panels in front of the doors resulting in soggy soundproofing and carpets, the top seal around the windshield is coming away in places from the body at the top, is this likely to be the problem?
Steve.
joey
Welcome to the forum... the seal could be the issue, or worse the windshield needs resealed. easy way to test is grab a garden hose and test for problem areas... could also be the sunroof.
steveflet
Thanks for that, i will give it a try once it stops raining long enough !
Steve.
David Antonoff
Steve.
I had the same problem with my D2, 2000. It seams that the water would come in from the base of the front right roof bar. Also I had the problem that the drain that took the condensate of the air conditioning unit out of the truck was pugged. This cause the condensate to over spil inside the truch on the floor of the rioght fron seat. Although I never resolved the first problem, I resolved the second one by cleaning the condensate drain line (under the truck and also clipping part of it off).
Regards form Mexico City,
David
Paul p
