Disco guru's HELP!!!! 3 Amigo help
bmccool21
hey guys im having the 3 amigo problems on my 04 disco and ive searched and searched and tried everything and i cant get them away!!!ive tried the following:
checked voltage at slabs ecu for each wss
shuttle valve repair kit
used modulator
another slabs unit from roverlandparts.com
flushed brakes
Thier not staying on all the time but keep comming on and its throwing codes for: modulator, module and short at one of the sensors!
any help is awesome guys!!!!
joey
Have you put your Rover on the Testbook computer to read what the issue is?
bmccool21
i took it to a euro shop to have it scanned and there was 3 codes, i dont have the exact descriptions but they were: abs modulator, abs pump, and wss short
bmccool21
edit: 3 codes from shop
pump failure 1
pump failure 2
shuttle valve switch
bmccool21
just got done putting some brake queit on the front brakes and rebleeding the system, still on. However i took it out in the snow and slammed the brakes and no abs pulsation at the pedel at all, would the abs not activate in the snow?
d2dave
Hi Im new here and trying to learn about my Discovery II ...
What is the three amigos? are they indicators? ABS , SERV ENG, TC, \@ where the @ is a truck going down a hill... these are the indicator lights im getting on my instrument display panel.. or is three amigos something else...
is that what you mean by three amigos?
joey
Three amigo's are ABS/TC/HDC (Hill Decent Control) i.e truck going down hill.
Serv Eng is engine codes and you should have them read with an OBDII scanner.
Disco Mike
Send me your tele number, I'll be glad to help you.
PE_in_UAE
