2011 RR HSE midrange door speaker remove
afchiefw
Mary Esther, FL
As the title says, I have the door panel off and the darn midrange speaker is encased in the door plastic. Most posts refer to a screw on case/ring that holds the speaker in place but there is none. Or at least I can't figure it out. The speaker area is riveted, no screws. Here is the picture, someone please help!
Shoshone
USA
Did you figure it out? Looks like the sub assembly is plastic/riveted to the panel. I have removed assemblies like this by carefully cutting away the minimum amount of the rivets to free the part. I attach the assembly using a hot glue gun around the remaining rivet structure. No experience with your particular issue, so proceed with caution.
