Tuffant Simpson 18" Alloys in Smoked Gray
DallasLoneStar
Dallas, TX
@Bronco1 I do run a 25mm lift, but I don't think it is necessary. The tire clearance on these trucks has more to do with width and correct wheel backspacing than tire height. I picked that size because it is the max that will still allow the truck to roll if the EAS fails. I used the IID Tool to lower the truck to the bump stops and was able to move around fine. I didn't really try going lock to lock and it may rub in that case, but still was able to move and turn ok, which satisfied me.
2010 LR4 Rick
Pasadena, CA
I just got these on today. Not sure if new color or not but I think I have mostly (or only) seen them in black. So, thought you guys may be interested in seeing this color. Tire is LT265/65R18 Nitto Ridge Grappler. I am super pleased with how it came out. Need to look into shoving the spare in this weekend (separate thread on that). Will also be putting on my Terrafirma sliders this weekend.
I have the same size tires but they are Goodyear Duratracs. The spare will fit, you just need to take a few pounds out.
rolledover
Fremont, MI
The Nitto’s in LT load range are just over 1/4” larger than the Duratracs so you may have to deflate the spare more, and/or remove the exhaust heat shield.
DallasLoneStar
Dallas, TX
I removed the heat shield and deflated almost all the way. Fit without shoving it in but I think it’s about maxed out haha. Which was my goal.
M32H32IS
Texas
Looks amazing. Been on the fence looking at a few wheel options but this may have sold me.
BTW that’s the best color for LR4’s.
DugLR4
NJ
did you need spacers? or any caliper fitment problems?
No. These were specifically designed to fit an LR4.
DugLR4
NJ
what was the offset that you got? I see they have two different sizes
Troy A
San Francisco, CA
I never liked them in black but these look awesome in grey. Thanks for sharing. I'm also interested in their new Kimberley and would love to see them on a truck.
