01 d2 SLS ACE- air spring or height sensor problem?
chris02disco
Hello and thanks in advance.
I have a 01 D2 SE7 with SLS & ACE and 69k. My problem is the driver side rear occasionally sinks. (common problem right), but I don't think the airspring is bad because it has stayed up for a week (didn't drive it we were on vacation). my guess is the height sensor because it never goes down to bumpstops. Anyway my question is- is there a way to fill the airspring and seal it to be up permanently. And then disable the SLS? I like the ride with the airsprings but I dont need the up and down functions. Also if I do convert to coil springs, is there a way to depressurize the system without the Testbook? Also is there still a 15% discount at Strutmaster for mentioning this forum?
Thanks again
If one is sinking sounds like a bad seal or just a slow leak. (normally "O" ring issue. But it could be a bad air bag.
