03 Disco se7. No spark, no fuel
aceinc
I've got an 03 disco with 148000 miles. No spark, and no fuel. Dash lights up, and it will turn over, but wont fire. Any ideas????
How did you check for spark? and Fuel....
This time of year, HOT, is is common to see the Crank Position Sensor fail. If that has happened, you will loose fuel and or spark.
mark D
just a thought did you reset the inertia switch I may have tripped. Its worth a lift of the hood. On the firewall passengers side there is a small item next to the blower pump. On top it has a rubber button. Push it see if it helps.
just a thought.
The inerta switch will only turn off the gas, should still have spark.
Paul p
