04 Discovery ATS sensor
ysaga
04 Discovery ECT sensor
Hi
I need help locating the ECT sensor
Thank you
jmrivera
Does this help???
ysaga
I got the power chip from ebay REAL PERFORMANCE CHIP LAND ROVER DISCOVERY 1994-2004 GA Item number: 250265269888 and I plan to connected to the ETC sensor
Don't expect much from this chip item you bought... if it was that easy and simple, don't you think the auto manufactures would include this?
If you decide to go ahead with this, do yourself a real favor and don't use those crimp clips as they will just cause more issues later.
Also remember that from 94 - 04 of a Disco there has been 3 complete upgades to the engine. 3.9 - 4.0 - and 4.6 in this you also have 2 different electricals.
ysaga
The chip , base on there info working exact like your ECU upgraded ?!
Get UP TO a 20% increase in MPG's, HP, and Torque!!!
> Faster acceleration
> Faster track times
> Improved 1/4 and 1/8th mile track times
> Better mid-range acceleration
> Higher top-end power
> Increased towing power
> Smoother shifting for both automatic and manual transmissions
> Smoother Idle
> Extends the time between costly engine tune-ups
> More low end torque
> Extends the life of your spark plugs
> 80% quicker throttle response time
> Cleaner engine heads (less repairs)
> Cleaner and faster revs
> Lengthens the life of your engine belts by reducing engine RPM's
> Smoother power in all power band levels
> Causes less stress on your engine, making your engine last even longer
> Extends the life of your oil and extends the life of your oil between oil changes
> Higher top speed and improved top-end torque
> Better climbing ability
> Improved HP and torque output in high altitude areas where the air is thin
> Increased passing ability
> Better and crisp throttle response
> Circuit protection
> Better mid-high RPM revs
> Street legal everywhere
> Cleaner spark plugs (less repairs and tune-ups)
jmrivera
When you get it installed, do the same as joey and provide updates....
ysaga
The instruction was to connect the chip to the ATS sensor or to the CTS sensor control temperature sensor ,at this moment I waiting instruction from manufacture to see if I will connect the chip to the ETC sensor will work
ysaga
ok I install the chip and the first day reactions the transmission is smoother regarding the mileage I will post the results soon ,the installations was easy remove the clip from ETC sensor remove the plag and you can reach the wire, install the chip and plag back in the wire from the sensor
PE_in_UAE
