04 RR Water Pump
USMC3051
I have a 04 RR and i believe the water pump is leaking and on its way out, i been having to fill up on coolant once a week know, i have what appears to be dried coolant sprayed all over the engine bay, I'm assuming that this is a result from the water pump leaking and fan spreading coolant all over. When the car is not running i can't se a leak anywhere, when the car is running the water pump appears to be wet all hoses are do not have a leak i just want to make sure before i go through the trouble of ordering and installing the pump that that is what it is if anyone has any suggestions it would be great thank you.
I would pressure test it if your not sure... most radiator shops will do this with little expense.
PE_in_UAE
