'05 LR3 Passenger side wet floor.
Thomasjt1870
Hello All,
Im having the same problem with my 05 LR3, my remotes were working fine until I had my sunroof drainage hose replaced two weeks ago. Took it back to the shop today and tech stated that everything was working properly. My remotes are still not working. I would like any suggestions to move forward; because i don't feel comfortable not being able to lock my car.
Can you not just demonstrate to your tech that your remote doesn't work?
Remote and sunroof/water ingress issues usually revolve around the wiring along the sill on the passenger side floor. Check for corrosion there.
pacomachine
Repaired the splice and bingo!
I opened up the passenger-side door sill and sure enough I found the splice with the green and white(well more of a yellowish white), I cut through and added about 6 inches of wire and some heat-shrink wrap, tested my keyfob and voilà, everything is working now!
Thanks !
Sogs
Join the club, there should be a full recall for this since it cause all sorts of bad **** to happen. Its a friken joke that a vehicle like this would leak as it does.
JoeS
Commerce
Here is a quick video about troubleshooting some of the potential problems causing water in the floorboard of an LR3 2005.
