1993 Lwb Trans Oil Temp Sensor
K
KARABITSU
On My 1993 Lwb My Transmission Oil Temp Light Flickers All The Time, Even At Start-up. I Suspect The Sensor Is Faulty But Can't Find It! Does Anyone Know Where It Is Located?
jholewka
There is most likely two switches as was the case on my 92 rrc. The first one is, facing the engine bay, bonnet open, inbetween the right bottom side of the rad and the power steering box, loceted in the trans cooler pipe. the second is on the transfer case, on top back and VERY close to parking brake drum. What happened with mine was the wire chafted on the pb drum and caused the light to come on itermittenly (sp) evven when cold. it's a ***** to get at with out removing stuff but it can be done. Good luck . hope this helps
Jim
