1996 range rover eas
scott.k
Hello, I recently got this car form my uncle and i am trying to figure out the suspension. i know that they come with eas stock, and the black covered compressor and eas stuff is still there under the hood on the driver's side, but the suspension on the car has coils and shocks (non- adjustable ones) and no air bags or whatever comes stock on the car that allows you to lower and lift it. THe eas setting on the dash has been disabled too, so it does not allow you to pick a ride height. I am looking to lift the car in the future to make it more capable for offroading because it is set at one height right now and its sits too low for me and im often bottoming out and the tires are pushed against the wheel wells. If you have any recommendations on the best way to lift it that would be appreciated too. I will be using ~36" tires when I lift it so I want to still have some good distance between the tire and wheel well. SO the lift will be a decent amount (probably 6+ inches).
thanks
scott
STQAddie91
