2005 LR3 18" Rims on a 2002 Disco II?
M
mumjh3
Does anyone know if you can put the 18" rims from a 2005 LR3 on a 2002 Discovery II? If so, Does it take a special adapter or different lugs? Thank You.
S
SteveA
I have answered this question at least 3 times before. Here goes again. Yes. Yes, both.
They will fit. You need a hub-centric adaptor and the lug nuts from the LR3. You can find a kit at bearmach.com or look on eBay. You need the adaptor or you will have vibration problems. The lug nuts have a different shape to the shoulder area where they contact the wheel.
Stephen
M
mumjh3
Thanks for the reply, Can I use the hubcentric adaptors that are listed as working with the Range Rover 19" rims or different adaptors? Thanks for the input.
S
SteveA
Yes, the adaptors that are designed to fit 03+ Range Rover wheels to 95-02 Range Rover should also work to fit LR3 wheels to 99+ Discovery II. The LR3 wheels will interchange with 03+ Range Rover by simply change to the correct lug nuts.
Stephen
T
tzucc
Stephen, do you know if there exists a 16" wheel that would fit the LR3???
We have this other thread going on this same topic as well, so forgive the redundancy.
S
SteveA
I haven't seen a 16" fittment. 17 is the smallest size available from the factory (UK only). With a rear brake disc diameter of 13.8" that doesn't leave much clearance inside a 16" wheel. The standard (US) 18" doesn't have much clearance with the brake caliper, so I really can't see a 16" wheel working.
Stephen
rwmathews
