2010 Range Rover Supercharged Air Suspension Valve Block
CJ84
MIssouri
I have a 2010 Range Rover that the suspension in the front will not stay up when it is below freezing outside and once it is down it takes a long time to go up or will fault out, so I am guessing that the valve is not closing all the way.
Would my thoughts of the valve freezing, having ice in it or some other cold related problem make since to you?
Where might the front air suspension valve block be located to?
Thank you
Corey Riley
