jastutte
- Joined
- Dec 6, 2008
- Posts
- 99
- Reaction score
- 7
changed out the original Hitachi compressor today with a HD Hitachi style compressor from Lucky8.
prior to changing the compressor, i was getting occasional codes stating the compressor was too slow to fill. i thought i had screen shot the code and exact language, but can't find it on my phone.
i pulled the compressor relay, disconnected the OG compressor, installed the new compressor, installed the new relay, and fired up the LR4.
cleared the codes and tried to change the ride height. after a few seconds i received the U3000-1D code. i switched back to the original relay. cleared the code and it immediately came back. repeated this with a second new relay that i had with the same results. i confirmed i had the Hitachi software. i did. updated it anyway. still no change.
did i get a bad compressor? should i switch back to the old one to test this? prior to switching out compressors i did not have the U3000-1D code.
Edit: i swapped the old compressor back in and cleared the code. U3000-1D came right back.
