Disclaimer: Links on this page pointing
to Amazon, eBay and other sites may include affiliate code. If you click them and
make a purchase, we may earn a small commission.
Out of nowhere the transmission over heat fluid light came on...Tranny still shifting good. Wonder if it is a sensor or something much deeper. Has anyone got any expierance in this matter?
First things first, check the fluid level to make sure you are not leaking fluid. Second I would spend a couple dollars and have the Transmission checked. Yes you can change the temp sensor and it may be the issue, but on the off chance that this is something more... find it now before it costs you $3000.00 to get your transmission fixed.
Gonna hav it looked at today by mechanic...He agrees on the temp sensor...It was still on this morning and it was 44 degrees. Maybe a loose wire or bad sensor. Let you know later...Thanks!
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
