looking into buying a 97 discovery SE V8I and have a few questions before i make purchase.
117000 mi 1. was underneath cleaning A/C drain Plug and on bottom of transmission case there looks to be a thin plate missing maybe 2-3 in diameter that is held on by 3 screws can see inside transmission. is this a problem should the plate be there. can e-mail picture of item
2. when should the timing chain be replaced
3 moving from Florida 20ft sea level to Colorado 6000 ft what should be done to engine when i move out there will be shipped not driven but do i need to adjust the air ratio intake if so is it something i can do or do i need to take to dealership
4. anything else i need to look for
thank you
Doug
thank you
Doug
