98 landrover discovery leaking
happy_85
98 disco LE
180,000 miles
V8 4.0L
Hi i need help dont know where this leak is coming from its driving me crazy
Thanks for the help
Sadly without seeing the complete engine bay it is very hard to tell from these 2 photos.
rob bartleman
A guess ventured....
From my rather limited experience of the 4.0 motor, I would suggest it is the valley gasket. In your second photo, look for the thick, black plastic loom that holds the wiring harness. Underneath that is a metal strip, bolts running through it, securing a rubber gasket that spans the front edge of your valley gasket. I believe oil is seeping past that gasket.
The bolts holding the metal strip are worth a slight tightening. But leak will likely continue. You can see that changing the whole valley gasket is quite a job!
Paul p
