ABS TC Brake
dlrnzo
Hello, 03 with 54k miles.
Getting a bit of squeak out of my front bakes during braking. Seems at a hard stop I get these 3 lights. They go out after the ingnition is turned off and on again. Is this a warning that brake pads/service is due or somting more sinister?
Thanks in advance!
Sounds like it is time to change the brake pad, possibly the rotors... 5 minutes removing a wheel will let you know.
Disco Mike
You have what is called the 3 Amigos, because from your squeaking brakes, which will need to be replaced. How mechanical are you, can you do a brake job, if so go to Atlantic British and look at the 3 different brake kits they offer, try for the middle set.
I can walk you thru this if you want.
You need to know that replacing the brakes won't make the lights go away, you will still need to see a mechanic with a scanner capable of clearing the codes.
